# Google Calendar - New/updated event trigger
The New/updated event monitors a calendar you specify for newly created or updated events. This trigger first fetches events created or updated within the last hour. On subsequent runs, it monitors the selected calendar in real time, fetching new or updated events as they occur.
ENSURE CALENDAR ACCESS
Ensure the calendar you plan to monitor is accessible from your connected account and that you have the necessary permissions to access events.
| Calendar | Select the calendar you plan to monitor for new or updated events. |
| Include deleted events? | Select whether to trigger jobs for deleted events. |
| Calendar ID | The Google ID of the calendar that contains the event. |
| Kind | The type of the resource, such as calendar#event. |
| Etag | The etag for the event. |
| Color ID | The Google ID for the color attached to the event. |
| Event import ID | The Google import ID for the event. |
| ID | The Google ID for the event. |
| Status | The status of the event, such as confirmed or cancelled. |
| URL | The URL for the event. |
| Created | A timestamp indicating when the event was created. |
| Updated | A timestamp indicating when the event was last updated. |
| Summary | The title of the event. |
| Description | The description of the event. |
| Location | The location of the event. |
| Start | The start time of the event. |
| End | The end time of the event. |
| Recurrence | The recurrence rules for the event. |
| Recurring event ID | The Google ID of the recurring event. |
| Original start time | Contains information about the start time of the event, such as:
| Visibility | The visibility of the event, such as Public or Private. |
| Reminders | Contains information about the event's reminder settings, such as:
| Show me as | The availability to display during the event, such as Busy or Available. |
| Hangout link | A link to the Google Hangout associated with the event. |
| Sequence | The sequence number of the event. |
| Guests can modify | Indicates whether guests can modify the event. |
| Guests can see other guests | Indicates whether guests can see other guests. |
| Attachments | Contains information about the event's attachments, such as:
| Attendees | Contains information about the event's attendees, such as:
| Creator | Contains information about the event's creator, such as:
| Organizer | Contains information about the event's organizer, such as:
