# Google Docs - Update document action
The Update document action updates the specified Google document.
| Document ID | Specify the ID of the document you plan to update. |
| Requests source list | Input a list datapill. |
| Replace with | Specify the text to be replaced with. |
| Find text | Specify the text to search in the document. |
| Match case | Select the appropriate value from the drop-down menu. |
| Document ID | A unique identifier for the Google Docs document. |
| Replies | Responses to comments or suggested edits within the document. |
| Replace all text | A function that allows replacing all occurrences of a specific text string within the document. |
| Occurrences changed | The number of times a specific text replacement occurred, such as 3 replacements made. |
| Write control | Mechanism to prevent conflicts when multiple users are editing; ensures only authorized changes are made. |
| Required revision ID | A specific document version identifier is needed to make changes, ensuring edits apply to the correct version. |
| Doc URL | The direct link to the Google Docs document, allowing access for viewing or editing. |
