# Google Docs - Get document action
The Get document action retrieves the document based on the specified document ID.
| Document ID | Specify the ID of the document you plan to retrieve. |
| Document ID | A unique identifier for the Google Docs document. |
| Title | A user visible name of the tab. |
| Body | The main body of the document tab. Refer to Google's documentation for the detailed schema (opens new window). |
| Content | The contents of the body. Refer to Google's documentation for the detailed schema (opens new window). |
| Document style | The style of the document tab. Refer to Google's documentation for the detailed schema (opens new window). |
| Background | The background of the document. Documents cannot have a transparent background color. Refer to Google's documentation for the detailed schema (opens new window). |
| Page number start | The page number from which to start counting the number of pages. |
| Margin top | The top page margin. Refer to Google's documentation for the detailed schema (opens new window). |
| Margin bottom | The bottom page margin. Refer to Google's documentation for the detailed schema (opens new window). |
| Margin right | The right page margin. Refer to Google's documentation for the detailed schema (opens new window). |
| Margin left | The left page margin. Refer to Google's documentation for the detailed schema (opens new window). |
| Page size | The size of a page in the document. Refer to the Google size schema (opens new window) documentation for more information. |
| Margin header | The amount of space between the top of the page and the contents of the header. Refer to the Google dimension schema (opens new window) documentation for more information. |
| Use custom header footer margins | Indicates whether the Document Style margin header (opens new window), Section Style margin header (opens new window), Document Style margin footer (opens new window), and Section Style margin footer (opens new window) settings are applied. If false, the default values in the Docs editor for header and footer margins are used. |
| Named styles | The named styles of the document tab. Refer to Google's documentation for the detailed schema (opens new window). |
| Styles | The named styles. Refer to Google's documentation for the detailed schema (opens new window). |
| Revision ID | The revision ID of the document. |
| Suggestions view mode | The suggestions view mode of the document. |
