# Google Drive - Update file permission action
This action updates a permission associated with a given file in Google Drive. Permissions are useful to transfer file ownership or to share a file with specific users, groups, or domains, or to make it accessible to anyone.
Google Drive Update file permission action
| File | The file with the permission you plan to update. Select a file or enter its ID. To find the file ID, right-click the file and select Share > Copy link. For example, if the URL is https://drive.google.com/file/d/123nyR2IjW_Rq84d3qEYRoq1/view, the file ID is 123nyR2IjW_Rq84d3qEYRoq1. Alternatively, you can find the file ID in the output of other Google Drive triggers and actions. |
| Permission | The permission you plan to update. Select a permission or enter its ID. The permission ID can be obtained from the List permissions action. |
| Role | The role granted by this permission. Select a role or use a custom value. Allowed role values are owner, organizer, fileOrganizer, writer, commenter, reader. |
| Use domain admin access? | Issues the request as a domain administrator, if the connected user is the admin of the domain owning a shared drive. This setting allows the domain admin to set permissions for shared drive files (opens new window) owned by their domain even if they aren't a member of the given shared drive. Default is set to No. |
| Transfer ownership | Transfer ownership of the file to the user email provided. The file must have been shared with the user and the Role must be set to owner. Defaults to No. |
| Remove expiration | Whether to remove the expiration date. |
| Kind | The kind of resource this is: drive#permission. |
| Type | The type of grantee: user, group, domain, or anyone. |
| Permission ID | The ID of this permission. |
| Email address | The email address of the user or group that was granted this permission. |
| Domain | The domain this permission refers to. |
| Role | The role granted by this permission. |
| View | The view for this permission. |
| Allow file discovery | Indicates whether this permission allows the file to be discovered through search. This is only applicable to permissions granted to domain or anyone. |
| Display name | The human-readable name for the permission grantee. user: User's full name. group: Name of the Google Group. Domain: Domain owning the shared drive. Not applicable to the type anyone. |
| Photo link | A link to the user's profile photo, if available. |
| Team Drive permission details | A list of permission details for the Team Drive. Contains the following output fields, in addition to List size and List index:
| Permission details | A list of permission details for the shared drive. Contains the following output fields, in addition to List size and List index:
| Deleted | Indicates whether the account associated with this permission has been deleted. This field only applies to user and group permissions. |
