# Google Gemini - Analyze text action
The Analyze text action performs a contextual analysis of a text to answer user-provided questions. The response datapill is returned empty if an answer isn't found in the text.
| Model | Select the Gemini model to use. |
| Source text | Enter the text to analyze. |
| Instructions | Enter instructions for the analysis. For example, you can specify an analysis technique or a question to answer. |
| Gemini reply | The text reply from Gemini. |
| Sexually explicit | The likelihood that the text contains sexually explicit content. NEGLIGIBLE indicates there is little to no risk of such content being present. |
| Hate speech | The likelihood that the text contains hate speech, such as discriminatory symbols or content targeting protected groups. NEGLIGIBLE indicates there is little to no risk of such content being present. |
| Harassment | The likelihood that the text contains harassing behavior, threats, or abuse toward individuals or groups. NEGLIGIBLE indicates there is little to no risk of such content being present. |
| Dangerous content | The likelihood that the text contains dangerous or harmful content such as violence, self-harm, or instructions for unsafe behavior. NEGLIGIBLE indicates there is little to no risk of such content being present. |
Last updated: 7/14/2025, 6:14:17 PM
