# Update rows in bulk action
This action updates multiple rows of a selected sheet in Google Sheets. This action supports up to 50,000 records and updates in batches of 500.
# Input fields
Input field Description
Google Drive Select either your personal drive or a team drive. Your personal drive is selected by default.
Spreadsheet Choose the spreadsheet where you plan to update rows in bulk.
Sheet Specify the sheet where you plan to update rows in bulk. Ensure the sheet contains at least one header row and one data row.
Row number Enter the row number from which the values must be updated, or use the Row number datapill from the output of other Google Sheets triggers and actions.
Rows Enter the values for the updated rows.
# Output fields
Output field Description
Spreadsheet ID The unique identifier of the spreadsheet.
Sheet name The name of the sheet within the spreadsheet.
All rows successfully updated? Indicates whether all rows were successfully updated.
Number of rows updated The number of rows that were updated.
Number of rows failed The number of rows that failed to update.
CSV contents of failed rows The CSV contents of the failed rows.
List of batches Information about the batches of updated rows.
Last updated: 12/4/2025, 5:18:41 PM
