# Google cloud storage Connector - List Objects
This action will list the details of all objects within a bucket in the Google cloud storage system.
Field | Description |
Bucket name Required | The name of the bucket. |
Folder path | List files and folders in a particular folder. If blank, it will list all objects in the selected bucket. Define the full path, for example folder_1/subfolder_1 . |
Delimiter | Default Delimiter is set to “/”. If you have a customized delimiter, please add it here. |
Start offset | Filter results to objects at or after startOffset. If endOffset is also set, the objects listed have names between startOffset (inclusive) and endOffset (exclusive). |
End offset | Filter results to objects before endOffset. If startOffset is also set, the objects listed have names between startOffset (inclusive) and endOffset (exclusive). |
Projection | Set of properties to return. Defaults to No ACL. |
Max results | Maximum results to be returned from API. Default value and maximum allowed value is 200 |
Page token | Token to specify the next page in a query. This can be found from the output of an earlier List buckets action. If the page token is null, there are no more pages. |
Versions | If ‘Yes’, lists all versions of an object as distinct results in order of increasing generation number. Set as ‘No’ by default. |
Object specific output fields will be dynamically rendered base on the objects you select.
