# IBM Db2 - Delete rows action
This action lets you delete rows based on certain criteria defined by a WHERE condition.
WARNING
This action should be tested and used with care, as it will PERMANENTLY delete rows in your table.
- Table
- Required field
- Select the target table or view. Optionally, toggle the input to text mode to enter the name of the table or view name as text.
- WHERE condition
- Optional field
- Specify the condition that must match the rows that the system deletes.
Warning: If this field is blank, the system deletes all rows.
- Rows affected
- The number of deleted rows.
Last updated: 1/16/2026, 4:23:47 PM
