# Microsoft Dynamics 365 - New or updated object trigger (batch)
New or updated object trigger (batch) in Microsoft Dynamics 365 checks for newly created or updated objects every specified interval and retrieves a batch of new or updated records as a single trigger event.
Field Description
Object Select any standard or custom Microsoft Dynamics 365 object to monitor. For example, Lead.
From Fetch new or updated object from the specified time.
Output fields Select the fields of the selected objects you plan to use in your recipe. All fields are returned if left blank.
Filter condition Condition to filter the records. Use OData $filter syntax. For example, contains(name, 'sample') and revenue gt 1000000. Learn more about filters (opens new window).
Batch size Number of records in a single trigger event, default batch size is 100. Minimum size is 1, maximum size is 1000.
Field Description
Range The range of record IDs retrieved from the search.
Time The time range of the records retrieved.
First ID The ID of the first record in the batch.
Last ID The ID of the last record in the batch.
Change details This contains information about the changed object, including the fields specified in the output fields.
Last updated: 1/19/2026, 4:31:14 PM
On this page
