# Microsoft Dynamics 365 - Search objects action (batch)
This action retrieves a list of objects in Microsoft Dynamics 365 that match the specified search criteria.
Field Description
Object name Select a standard or custom Microsoft Dynamics 365 object to monitor. For example, Lead.
Result list size Number of records retrieved. Minimum is 1, maximum is 5000. Defaults to 200.
Output fields Select the fields of the selected objects you plan to use in your recipe.
Filter condition Condition to filter the records. Use OData $filter syntax. For example, contains(name, 'sample') and revenue gt 1000000. Learn more about filters (opens new window).
Order by Specify the order in which items are returned.
Expand Expand navigation properties in the related entity set.
Next page URL Next page URL, returned by a previous call, to request the next page of results.
The output datatree contains a list of objects that match the search criteria. Each object contains information, such as ID and other attributes.
Field Description
Records A list of records that match the search criteria.
Next page URL URL to fetch the next page of results.
Last updated: 1/19/2026, 4:31:14 PM
On this page
