# Microsoft Graph API - Update record action
The Update record action enables you to update a record, such as a list, using its object ID.
Input field Description
Object Select the object you plan to update from the drop-down menu. Fields load dynamically based on the selected object.
The output fields depend on the object you select in the input. Each object returns a unique set of fields based on its type.
On this page
