# PGP tools by Workato – Decrypt data action
The Decrypt data action decrypts encrypted file content using the private key and passphrase provided in the connection.
| Encrypted content | Provide the encrypted content to decrypt. Map a File content datapill or paste the encrypted string directly. |
| Use public key from connection? | Select Yes to use the public key from the connection for signature verification. |
| Verification public key | Provide a public key to verify the signature of the encrypted content. This field generates when you set Use public key from connection? field to No. |
| Ignore MDC error | Select Yes to skip MDC (Modification Detection Code) errors when decrypting. |
| Decrypted contents | The decrypted contents of the file. |
