# Positional file tool
The Positional file tool connector parses complex flat files into structured JSON outputs. It supports a broad range of parsing use cases and accommodates both Fixed width (delimiter) and Dynamic width (position-length) formats with Single schema or Multiple schemas. It also handles Linear fields or Child fields (hierarchically nested) data structures in flat files.
# How to connect to Positional file tool
This connector doesn't require authentication or a connection setup, however, you must install this connector from the community library before you can use it in your workspace.
# Download the Positional file tool connector from the Community library
Complete the following steps to install the connector from the community library (opens new window):
Open the recipe editor and search for a connector. Alternatively, you can search for a connector in the community library (opens new window).
Search for recipe editor Search for community connectors in the recipe editor
Click installClick Install
Last updated: 10/29/2025, 11:42:27 PM
