# Quick Base
Quick Base (opens new window) is a no-code application development platform that allows business users to quickly create custom business software.
Workato's Quick Base connector enables you to build even more automation around Quick Base and connect with other applications.
# API version
The Quick Base connector uses Quick Base HTTP API (opens new window).
# How to connect to Quick Base on Workato
The Quick Base connector support 2 types of authentication:
- Username/Password
- User token
# Username/Password authentication
To connect using username/password, input your Quick Base Sub-domain and Username / Password, as seen in the example below.
# User token authentication
This type of authentication allows you to grant access to Workato, without disclosing your Quick Base username and password. To use this authentication, you need to input your Quick Base Sub-domain and User token, as seen in the example below.
You can find user token in Quick Base from Your profile name
> My preferences
> Manage User Tokens
When creating a new token, please make sure to grant access to the Quick Base apps that you want Workato to access.
Last updated: 5/23/2025, 7:33:56 AM
