S3 Data Lake(opens new window) is a centralized repository that allows you to store your structured and unstructured data at any scale. You can use the S3 Data Lake connector in Workato to run custom AWS Glue jobs and manage datasets in your AWS environment.
Enter the Access key ID and Secret access key from your IAM user. Go to IAM > Users > [your user] > Security credentials in the AWS console to retrieve these credentials. Refer to Use IAM role-based authentication for AWS Services for more information.
Enter the AWS Region where your S3 buckets and Glue jobs reside. For example, your region is us-east-1, if your console URL is https://us-east-1.console.s3.amazon.com.
Create a new connection and select the S3 Data Lake connector.
Enter a Connection name to identify the connection. Connection name
Select the Location where you plan to store the connection.
