# SAP Business One - Create records batch action
The Create records batch action enables you to create multiple records in SAP Business One.
SAP Business One - Create records batch actionSAP Business One Create records batch action
# Input fields
Input Field Description
Object Specify the object you plan to create. Fields load dynamically based on the object you select.
# Output fields
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps.
Last updated: 12/11/2025, 6:57:33 PM
