# SAP Business One - Delete record action
The Delete record action enables you to delete a record in SAP Business One.
# Input fields
| Input Field | Description |
| Object | Specify the object you plan to delete. Fields load dynamically based on the object you select. |
# Output fields
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps.
Last updated: 12/11/2025, 6:57:33 PM
