# Update records batch action
The Update record action enables you to Update a record in SAP Business One.
SAP Business One Update records batch action
# Input fields
| Input Field | Description |
| Object | Specify the object you plan to Update. Fields load dynamically based on the object you select. |
# Output fields
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps.
