# SAP Fieldglass - Custom action
The Custom action allows you to build and execute an HTTP request with your SAP Fieldglass connection.
Custom action
Input Field | Description |
Request type | Select the HTTP method of the request, such as POST, GET, PUT, or DELETE. |
Path | Define the API endpoint path to append to the base URI. Use an absolute URI to override the base URI if necessary. |
URL parameters | Add any required URL parameters to refine the API call. |
Request body parameters | For actions like POST or PATCH that modify data, define the JSON structure of the data payload. |
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps.
