# SAP SuccessFactors LMS - Assign object to user action
The Assign object to user action enables you to assign an object to a user in SAP SuccessFactors LMS.
| Input Field | Description |
| Object | Specify the object you plan to create. Fields load dynamically based on the object you select. |
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to the subsequent steps.
Last updated: 1/19/2026, 4:31:14 PM
