# SFTP - Change permission of a file action
The Change permission of a file action updates access permissions for a specified file on an SFTP server. This action replaces the existing permissions with new values you provide.
| File path | Provide the full path of the file, including the file name. For example: /folder1/folder2/filename.csv. |
| Apply permissions method | Choose how to apply file permissions. Options include Custom permission and Select permission. Defaults to Select permission. |
| Permission for Owner | Select one or more permissions for the file owner. Available options include Read, Write & Execute (7), Read & Write (6), Read & Execute (5), Read Only (4), Write & Execute (3), Write Only (2), Execute Only (1), and No Permission (0). This field appears when you select Select permission as the Apply permissions method. |
| Permission for Group | Select one or more permissions for the group. Available options include Read, Write & Execute (7), Read & Write (6), Read & Execute (5), Read Only (4), Write & Execute (3), Write Only (2), Execute Only (1), and No Permission (0). This field appears when you select Select permission as the Apply permissions method. |
| Permission for Others | Select one or more permissions for others. Available options include Read, Write & Execute (7), Read & Write (6), Read & Execute (5), Read Only (4), Write & Execute (3), Write Only (2), Execute Only (1), and No Permission (0). Defaults to None. This field appears when you select Select permission as the apply permissions method. |
| Permission code | Enter a 3-digit permission code. Defaults to 644. This field appears when you select Custom permission as the Apply permissions method. |
| File path | Returns the full path of the file. |
| Updated permission code | Returns the three-digit permission code applied to the file. |
Last updated: 3/11/2026, 5:47:01 PM
