# Search files/folders action
This action allows you to search for files, folders, or both within a given folder path in your SFTP server. The action will fail if the path is not found.
| Parent folder path | Provide the path of the parent folder. All of its files and subfolders will be searched. Search does not include contents of the subfolders. Example: /folder1/folder2 |
| Entity | Select whether to search for files, folders, or both. Default is Files. |
| Search term | Enter the search term. Regular expression matches are supported. For example, to search for all CSV files in the folder, use *.csv. |
The output of this action is a list of records with each record containing the following details:
| Name | The name of the file or folder. |
| Symlink | Whether this file or folder contain links to other files. |
| Size | The size of the file or folder. |
| Owner | The designated owner of the file or folder. |
| Group | The group that this file or folder belongs to. |
| Permissions | The permissions enabled on this file or folder. |
| Last accessed time | The last time this file or folder was accessed. |
| Last modified time | The last time this file or folder was modified. |
| Folder? | Whether this item is a folder. |
| List size | Total number of items in the list. |
| List index | Position of each item in the list, starting at 0. |
