# UKG Pro (Recruiting) - New or updated records trigger
The New or updated records trigger monitors UKG Pro (Recruiting) for newly created or updated records.
| Object | Specify the type of object to monitor. Additional fields load dynamically based on the object you select. |
| When first started, this recipe should pick up events from | Set the date and time to start picking up trigger events. Defaults to 1 hour ago if left blank. You can't change this value after the recipe runs or tests successfully. |
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps. For example, the Candidate object has the following output schema:
| ID | The unique ID of a candidate in GUID format. |
| Creator | The creator of a candidate record. |
| Created at | The date and time a candidate was created. |
| Util person ID | The UKG Pro person ID. |
| EEID | The employee identifier. |
| Preferred locale | The preferred language of the candidate. |
| Integration user ID | The user ID used in 3rd party integrations, such as background check integrations. |
| Is internal | An indicator of whether or not a candidate is an internal employee. |
| Is active | An indicator of whether or not a candidate is an active employee. |
| Updated at | The date and time a candidate was last updated |
Last updated: 1/2/2026, 5:56:05 PM
