# Workday REST - New worker trigger
This trigger picks up workers that are created in your Workday instance. Each row is processed as a separate job. When first started, all existing workers will be processed as individual jobs. Subsequently, it triggers when a worker is created. It checks for new rows once every poll interval.
New worker trigger
# Input fields
Input field | Description |
Name filter | Optional. Use this to filter workers by name. Only workers with names that start with the provided text will be processed. |
# Output fields
Output field | Description |
Descriptor | Worker full name |
ID | Workday ID or the worker record. |
HREF | API resource URL of the worker record. |
Primary supervisory organization | Primary supervisory organization object of this worker record. Contains descriptor (full name), Workday ID and HREF. |
Business title | Full business title of the worker record. |
Primary work email | Primary work email of the worker record. |
Is manager | Boolean data. True if the worker record is a manager. |
Primary work phone | Primary phone number of the worker record. |
Location | Location object of this worker record. Contains descriptor (full name) and Workday ID. |
Primary work address text | Full primary address of the worker record. |
Supervisory organizations managed | Supervisory organizations managed by the worker record. |
Years of service | Years of service, as an integer, by the worker. |
Date of birth | Date of birth of the worker record. Format: YYYY-MM-DD |
