# Workday REST - Search workers action
Use this action to search for workers by name.
# Input fields
| Name filter | This must be at least 3 characters long and is not case sensitive. Workers with names that start with the provided value will be returned. |
# Output fields
Output is a list of workers. Each worker object has an output defined in the following table.
| Descriptor | Worker full name |
| ID | Workday ID or the worker record. |
| HREF | API resource URL of the worker record. |
| Primary supervisory organization | Primary supervisory organization object of this worker record. Contains descriptor (full name), Workday ID and HREF. |
| Business title | Full business title of the worker record. |
| Primary work email | Primary work email of the worker record. |
| Is manager | Boolean data. True if the worker record is a manager. |
| Primary work phone | Primary phone number of the worker record. |
| Location | Location object of this worker record. Contains descriptor (full name) and Workday ID. |
| Primary work address text | Full primary address of the worker record. |
| Supervisory organizations managed | Supervisory organizations managed by the worker record. |
| Years of service | Years of service, as an integer, by the worker. |
| Date of birth | Date of birth of the worker record. Format: YYYY-MM-DD |
