# Connector building - Useful coding patterns
There are some known limitations to Workato's platform that have fixes in the works. In the meantime, here are some ways that you can easily solve for any limitations that you might find when building a custom connector.
# Handling special characters
One known limitation of relates closely to datapills in Workato. When input or output fields are defined with names that have these special characters, input fields don’t show up and output datapills render incorrectly.
For example, schema defined where
Would not show up as a string input field and datapills would turn render as long strings instead of datapills.
When names of schema have special characters, datapills are renders incorrectly
instead of
There is a need to render them properly by switching out the special characters in their names
Fortunately, there is a workaround which we highly recommend you build into your connector as well. ( You could even copy and paste the following if it fits.) We create a series of 3 methods, format_schema, format_payload, format_schema which can be called at the beginning and end of each execute block. We had done something similar in our earlier example when defining our action.
# format_schema
Sample code snippet:
format_schema: lambda do |schema|
if schema.is_a?(Array)
schema.map do |array_value|
call('format_schema', array_value)
end
elsif schema.is_a?(Hash)
schema.map do |key,value|
if %w[name].include?(key.to_s)
value = call('replace_special_characters',value.to_s)
elsif %w[properties toggle_field].include?(key.to_s)
value = call('format_schema', value)
end
{ key => value }
end.inject(:merge)
end
end,
Since fields where names contain keys cause errors, we need a service method that can take invalid schema and convert any names into formats we can handle. The method above recursively searches through a given schema and replaces any special characters with a valid string. For example,
control_type: "text",
label: "Txn date",
type: "string",
Would be converted to
label: "Txn date",
type: "string",
This allows the field to be displayed in Workato with no observable difference to the end user as labels are preserved. This service method can be called on either static or dynamic schema.
# format_payload
format_payload: lambda do |payload|
if payload.is_a?(Array)
payload.map do |array_value|
call('format_payload', array_value)
end
elsif payload.is_a?(Hash)
payload.map do |key, value|
key = call('inject_special_characters',key)
if value.is_a?(Array) || value.is_a?(Hash)
value = call('format_payload', value)
end
{ key => value }
end.inject(:merge)
end
end,
This method should be called when input from the job is passed through the execute block. At this stage, this method recursively searches through the input hash and finds any markers that a special character was replaced and transforms it back to its original form. The return from this method is a formatted payload with all special characters replaced back in.
# format_response
format_response: lambda do |payload|
call('format_response', array_value)
end
key = call('replace_special_characters',key)
value = call('format_response',value)
end
{ key => value }
end.inject(:merge)
end
end,
When working with responses, we still need to match them back to the Workato valid schema. As such, we need to transform the keys in our responses from our network traffic back to replace any special characters. This should be done immediately after we get a response back from a HTTP call.
# replace_special_characters and inject_special_characters
Samples code snippet:
replace_special_characters: lambda do |input|
input.gsub(/[-<>!@#$%^&*()+={}:;'"`~,.?|]/,
'-' => '__hyp__',
'<' => '__lt__',
'>' => '__gt__',
'!' => '__excl__',
'@' => '__at__',
'#' => '__hashtag__',
'$' => '__dollar__',
'%' => '__percent__',
'^' => '__pwr__',
'&' => '__amper__',
'*' => '__star__',
'(' => '__lbracket__',
')' => '__rbracket__',
'+' => '__plus__',
'=' => '__eq__',
'{' => '__rcrbrack__',
'}' => '__lcrbrack__',
';' => '__semicol__',
'\'' => '__apost__',
'`' => '__bckquot__',
'~' => '__tilde__',
',' => '__comma__',
'.' => '__period__',
'?' => '__qmark__',
'|' => '__pipe__',
':' => '__colon__',
'\"' => '__quote__'
end,
inject_special_characters: lambda do |input|
input.gsub(/(__hyp__|__lt__|__gt__|__excl__|__at__|__hashtag__|__dollar__|\__percent__|__pwr__|__amper__|__star__|__lbracket__|__rbracket__|__plus__|__eq__|__rcrbrack__|__lcrbrack__|__semicol__|__apost__|__bckquot__|__tilde__|__comma__|__period__|__qmark__|__pipe__|__colon__|__quote__|__slash__|__bslash__)/,
'__hyp__' => '-',
'__lt__' => '<',
'__gt__' => '>',
'__excl__' => '!',
'__at__' => '@',
'__hashtag__' => '#',
'__dollar__' => '$',
'__percent__' => '%',
'__pwr__' => '^',
'__amper__' => '&',
'__star__' => '*',
'__lbracket__' => '(',
'__rbracket__' => ')',
'__plus__' => '+',
'__eq__' => '=',
'__rcrbrack__' => '{',
'__lcrbrack__' => '}',
'__semicol__' => ';',
'__apost__' => '\'',
'__bckquot__' => '`',
'__tilde__' => '~',
'__comma__' => ',',
'__period__' => '.',
'__qmark__' => '?',
'__pipe__' => '|',
'__colon__' => ':',
'__quote__' => '"'
end
# Avoid encoded query parameters
Workato's SDK automatically encodes query parameters in GET requests, which can break requests for APIs that expect exact formatting. To avoid this, build the query string manually and append it directly to the URL.
For example:
url = "https://api.example.com/reports"
query_string = "addressVerification=true&poi[latitude]=#{input['latitude']}&poi[longitude]=#{input['longitude']}"
get("#{url}?#{query_string}")
This preserves the exact casing and structure required by the API. Use this pattern when the API expects raw query strings or rejects encoded characters.
# Header casing in SDK console
Case-sensitive headers may appear with incorrect casing when you test connectors in the SDK console.
This issue affects only the console interface. The SDK console formats header names for display, but Workato sends the request with the exact casing defined in your code.
For example:
case_sensitive_headers(BPMCSRF: connection['BPMCSRF'],
Cookie: connection['Cookie'])
In the console, a header like BPMCSRF may display as Bpmcsrf, but the actual request uses the correct casing. You don't need to change your code.
# Summary
Object based actions and triggers in Connectors are something we highly recommend. Not only do they improve user experience for your users but they also make it so much easier to extend your connector when done properly. Here are a few of the main concepts we covered:
- Defining the base schema of each object in a service method. Don’t forget to include an input argument that allows you to adjust the schema based on the action type.
- Use object_definitions to pull the proper input and output field schema based on the object selected
- When defining actions or triggers, make sure to declare all blocks especially
descriptionblocks. This will vastly increase usability for your users. - Contain any general processing inside execute blocks but leverage on dedicated object execute methods (i.e.
create_invoice_execute)for anything specific. i.e. Useformat_paylodandformat_responsein the execute block before using thecreate_#{object}_executemethod.
# Usability rules
Great connectors not only have great architecture but look and feel great to use. Read on to find out more about how you can make your connector easy to use.
Last updated: 6/23/2025, 4:25:04 PM
