# Manage project properties
The Project properties interface enables you to perform the following actions:
# Create a project property
Complete the following steps to create a project property:
Go to Projects.
Select a project.
Go to Settings > Project properties.
Click + Add new property.
Enter a Property name and Value. Ensure the Property name is descriptive and unique.
Click ✓ Save to save the property.
Save your project property
DUPLICATE PROPERTY NAMES ERROR
Ensure project property names are unique. If you attempt to create a project property with a name already in use within the same project, Workato displays a warning message and prevents you from saving it.
Duplicate names error
# Edit a project property
Complete the following steps to edit a project property:
Go to Projects.
Select a project.
Hover over the last column of the property you plan to edit and click the Edit (pencil icon) when it appears.
Click Edit (pencil icon)
Edit the property.
Click ✓ Save to save the changes.
Save your changes
# Delete a project property
Complete the following steps to delete a project property:
Go to Projects.
Select a project.
Hover over the last column of the property you plan to delete and click Delete (trash icon) when it appears.
Click Delete.
DELETED ACTIVE PROJECT PROPERTIES ERROR
When you delete a project property, recipes using the deleted property display a Please replace invalid datapill(s) error message. To resolve this error, replace or remap the invalid datapill with a valid one.
Replace invalid datapills
