# String functions
You can use the following string functions in calculated columns to manipulate, format, and analyze text-based values within Insights dashboards.
ALIASES
You can search for a function using its alias.
For example, if the function starts_with has the alias startswith:
- When you type
startswi, Insights suggests thestarts_withfunction. - When you type
startswith, Insights rewrites it asstarts_with.
# contains
Returns TRUE if string contains the search_key and FALSE if otherwise.
Returns <null> if either input is null.
- Return type:
BOOLEAN
contains(string, search_key, case_sensitive)
# Parameters
| Parameter | Type | Description |
string | VARCHAR | The string to search in. |
search_key | VARCHAR | The substring to search for. |
case_sensitive | BOOLEAN | Optional. Determines whether the search is case-sensitive. Defaults to true. |
# Example
This example filters records where product descriptions contain the organic keyword, ignoring case:
= contains( Description
, "organic", false)
You can use this function to segment sales data by product attributes.
# starts_with
Returns TRUE if string starts with the start_key and FALSE if otherwise.
- Return type:
BOOLEAN - Alias:
startswith
starts_with(string, start_key, case_sensitive)
# Parameters
string | VARCHAR | The string to check. |
start_key | VARCHAR | The starting substring to check with. |
# Example
This example filters projects for a specific department based on the project name, which starts with the department code.
For example, consider the project name [P&E] Test Automation, where [P&E] is the department code:
= starts_with( Project name
, "[P&E]")
# ends_with
Returns TRUE if string ends with the end_key and FALSE if otherwise.
- Return type:
BOOLEAN - Alias:
endswith
ends_with(string, end_key, case_sensitive)
# Parameters
end_key | VARCHAR | The ending substring to check with. |
# Example
This example retrieves transactions where payment references end with USD:
= ends_with( Payment reference
, "USD")
You can use this function for use cases that require currency-specific financial reporting.
# concat
Returns a concatenation of all the string inputs.
- Return type:
VARCHAR
concat(string_1, .., string_n)
# Parameters
string_1, .., string_n | VARCHAR | One or more strings to be concatenated. |
# Example
This example combines first and last names into a single column containing the full name:
= concat( First name
, " ", Last name
You can use this function to create employee dashboards.
# substring
Returns a substring from string of substring_length starting at start_index.
If no substring_length is provided, the rest of the string from the start_index is returned.
- Return type:
VARCHAR - Alias:
substr
substring(string, start_index, substring_length)
# Parameters
string | VARCHAR | The string to extract from. |
start_index | BIGINT | The starting position of the substring to extract (1-based index). |
substring_length | BIGINT | Optional. The length of the substring to extract. If missing or greater than the length of the original string, the returned substring will run to the end of the original string. |
# Example
This example extracts the product category from a product code, where the product category is represented by the first four characters of the product code:
= substring( Product code
, 1, 4)
You can use this function to visualize product sales for different categories.
# trim
Removes any leading and/or trailing characters that matches the key from string.
- Return type:
VARCHAR
trim(specification, key, string)
# Parameters
specification | VARCHAR | Optional. Specifies which part of the string to trim. Allowed values include "leading", "trailing", and "both". Defaults to "both". |
key | VARCHAR | Optional. The character to remove from the string. Defaults to " " (space). |
string | VARCHAR | The string to trim. |
# Example
This example removes leading dollar signs from revenue values:
= trim("leading", "$", Revenue
You can use this function to create clearer visualizations in a financial dashboard.
# replace
Replaces all instances of search_key with replacement in string.
- Return type:
VARCHAR
replace(string, search_key, replacement)
# Parameters
string | VARCHAR | The string to search in and modify. |
search_key | VARCHAR | The substring to search for and replace. |
replacement | VARCHAR | The substring to insert into the original string. |
# Example
This example replaces underscores in product names with spaces:
= replace( Product name
, "_", " ")
You can use this function to enhance readability in product performance dashboards.
# lower
Converts string to lowercase.
- Return type:
VARCHAR
lower(string)
# Parameters
string | VARCHAR | The input string to covert to lowercase. |
# Example
This example converts region names to lowercase:
= lower( Region name
You can use this function to create accurate grouping and consistent labels in a dashboard.
# upper
Converts string to uppercase.
- Return type:
VARCHAR
upper(string)
# Parameters
string | VARCHAR | The input string to convert to uppercase. |
# Example
This example converts region names to uppercase:
= upper( Region name
# titleize
Returns the input string with the first letter of each word in uppercase and the subsequent letters in lowercase.
- Return type:
VARCHAR - Alias:
initcap(string)
titleize(string)
# Parameters
string | VARCHAR | The input string to titleize. |
# Example
This example formats product names in title case:
= titleize( Product name
You can use this function to create a polished presentation in sales dashboards.
# left
Returns the leftmost substring of the specified length.
- Return type:
VARCHAR
left(string, substring_length)
# Parameters
substring_length | BIGINT | The number of characters to return from the left side of the string. |
# Example
= left( Product code
, 4)
# Related to
# right
Returns the rightmost substring of the specified length.
- Return type:
VARCHAR
right(string, substring_length)
# Parameters
substring_length | BIGINT | The number of characters to return from the right side of the string. |
# Example
This example extracts the last six characters of transaction IDs, which represent the transaction date:
= right( Transaction ID
, 6)
For example, if the Transaction ID is
XJBDJF120424, this function returns 120424.
You can use this function to analyze transaction volume over time.
# Related to
