# Workato CLI command reference
Command reference for the Workato Platform CLI tool.
# workato
Root command for the Workato Platform CLI. Provides access to all Workato automation and integration management capabilities.
# Usage
workato [GLOBAL_OPTIONS] <COMMAND> [COMMAND_OPTIONS]
# Options
| Option | Description |
| --profile TEXT | Profile to use for authentication and region settings. You can also set using the `WORKATO_PROFILE` environment variable. |
| --version | Show the CLI version and exit. |
| --help | Show help message and available commands. |
# Result
Displays available commands and global options when run without arguments.
# Examples
Show all available commands.
workato --helpUse a specific profile.
workato --profile production recipes list# workato init
Initialize the Workato CLI for a new project. Sets up authentication, selects region, and configures project workspace.
# Usage
workato init [OPTIONS]
# Options
| --profile TEXT | Profile name to use. Creates new profile if it doesn't exist. |
| --region CHOICE | Workato region, such as US, EU, JP, AU, SG, or custom. |
| --api-token TEXT | Workato API token for authentication. |
| --api-url TEXT | Custom API URL. Required when using a custom region. |
| --project-name TEXT | Name text for the new project. |
| --project-id INTEGER | Use existing project ID. |
| --non-interactive | Run without prompts. Requires all options. |
| --output-mode CHOICE | Output format, including table (default) and JSON. |
# Result
Creates configuration files, authenticates with the Workato API, and sets up project structure.
# Examples
Interactive setup
workato initNon-interactive setup with a specific region.
workato init --profile prod --region eu --api-token wrkprod-xxx --project-name 'Production Integration'# workato workspace
Display current workspace information, including active profile, project, and connection status.
# Usage
workato workspace
# Result
Shows current profile, project details, API endpoint, and authentication status.
# Examples
Check current workspace.
workato workspace# workato pull
Pull latest assets from Workato workspace to local project directory. Synchronizes recipes, connections, and data tables.
# Usage
workato pull [OPTIONS]
# Options
| --force | Overwrite local changes without confirmation. |
# Result
Downloads and updates local files with latest versions from Workato workspace.
# Examples
Pull the latest changes.
workato pullForce pull and overwrite local changes.
workato pull --force# workato push
Push local changes to Workato workspace. Uploads modified recipes, connections, and other assets.
# Usage
workato push [OPTIONS]
# Options
| --force | Push changes without confirmation prompts. |
| --restart-recipes | Automatically restart affected running recipes after push. |
# Result
Uploads local changes to Workato workspace and optionally restarts recipes.
# Examples
Push changes with confirmation.
workato pushForce push and restart recipes.
workato push --force --restart-recipes# workato profiles list
List all configured authentication profiles with their regions and status.
# Usage
# Result
Displays table of profiles showing name, region, API endpoint, and active status.
# Examples
Show all profiles.
workato profiles list# workato profiles use
Switch to a different authentication profile for subsequent commands.
# Usage
workato profiles use <PROFILE_NAME>
| Input | Description |
| PROFILE_NAME | Name of the profile to activate. |
# Result
Sets the specified profile as active for future CLI operations.
# Examples
Switch to production profile.
workato profiles use production# workato profiles status
Displays the current active profile and its configuration details.
# Usage
# Options
| --verbose, -v | Optional. Show detailed profile information including API endpoint and authentication status. |
| --json` | Optional. Output profile status in JSON format for scripting. |
# Result
Shows the name of the active profile, associated workspace, and connection status.
# Examples
Check which profile is currently active.
workato profiles statusView detailed profile configuration.
workato profiles status --verboseGet profile status in JSON format for automation.
workato profiles status --json# workato profiles delete
Remove a profile from the CLI configuration.
# Usage
workato profiles delete <PROFILE_NAME>
| PROFILE_NAME | Name of the profile to delete. |
# Result
Removes the specified profile and its associated configuration.
# Examples
Delete development profile.
workato profiles delete development# workato projects list
List all available projects in the current Workato workspace.
# Usage
# Result
Displays table of projects with ID, name, description, and folder count.
# Examples
Show all projects.
workato projects list# workato projects use
Switch to a different project context for CLI operations.
# Usage
workato projects use <PROJECT_NAME>
| PROJECT_NAME | Name of the project to switch to. |
# Result
Changes active project context and updates local workspace.
# Examples
Switch to customer integration project.
workato projects use 'Customer Integration'# workato recipes list
List recipes in the workspace with filtering and pagination options.
# Usage
workato recipes list [OPTIONS]
# Options
| --folder-id INTEGER | Filter recipes by folder ID. |
| --running | Show only currently running recipes. |
| --page INTEGER | Page number for pagination. Default is 1. |
| --per-page INTEGER | Number of recipes per page. Default is 10. Maximum is 100. |
| --adapter-names-all TEXT | Comma-separated adapter names. Recipes must use all specified. |
| --adapter-names-any TEXT | Comma-separated adapter names. Recipes must use any specified. |
| --order CHOICE | Sort order: activity or default. |
# Result
Displays table of recipes with ID, name, status, folder, and last activity.
# Examples
List all recipes
workato recipes listShow running recipes in specific folder
workato recipes list --folder-id 123 --runningFind recipes using Salesforce
workato recipes list --adapter-names-any salesforce# workato recipes validate
Validate recipe JSON file syntax and structure against Workato schema requirements.
# Usage
workato recipes validate --path <FILE_PATH>
# Options
| --path TEXT | Path to the recipe JSON file to validate. |
# Result
Reports validation results including syntax errors, missing fields, and schema violations.
# Examples
Validate recipe file.
workato recipes validate --path ./my_recipe.recipe.json# workato recipes start
Start a stopped recipe by ID or name, enabling it to process triggers and execute actions.
# Usage
workato recipes start [OPTIONS]
# Options
| --id TEXT | Recipe ID to start. |
| --name TEXT | Recipe name to start. Use as an alternative to ID. |
| --folder-id TEXT | Folder ID to help locate recipe by name. |
# Result
Starts the specified recipe and reports the new running status.
# Examples
Start recipe by ID.
workato recipes start --id 12345Start recipe by name.
workato recipes start --name 'Daily Sales Report'# workato recipes stop
Stop a running recipe, preventing it from processing new triggers while completing current jobs.
# Usage
workato recipes stop [OPTIONS]
# Options
| --id TEXT | Recipe ID to stop. |
| --name TEXT | Recipe name to stop. Use as alternative to ID. |
# Result
Stops the specified recipe and reports the new stopped status.
# Examples
Stop recipe by ID.
workato recipes stop --id 12345Stop recipe by name in specific folder.
workato recipes stop --name 'Data Sync' --folder-id 456# workato recipes update-connection
Updates the connection used by a specific connector in a stopped recipe.
# Usage
workato recipes update-connection RECIPE_ID [OPTIONS]
# Options
| --adapter-name, -a | Name of the adapter or connector to update. |
| --connection-id, -c | Required. ID of the connection from your workspace to use. Must be a valid connection ID. |
# Result
The recipe's connection for the specified adapter is updated to use the new connection. The recipe must be stopped before you can perform this operation.
# Examples
Update a Salesforce connection in a recipe.
workato recipes update-connection 12345 --adapter-name salesforce --connection-id 67890Switch Slack connection for a notification recipe.
workato recipes update-connection 54321 -a slack -c 98765# workato connections list
List all connections in the workspace with filtering options for provider, folder, and external ID.
# Usage
workato connections list [OPTIONS]
# Options
| --provider TEXT | Filter by connector provider. |
| --folder-id INTEGER | Filter connections by folder ID |
| --external-id TEXT | Filter by external identifier for runtime connections. |
| --parent-id INTEGER | Filter by parent connection ID |
# Result
Displays table of connections with ID, name, provider, status, and folder information.
# Examples
List all connections.
workato connections listShow Salesforce connections.
workato connections list --provider salesforceList connections in specific folder.
workato connections list --folder-id 789# workato connections create
Create a new connection for a specific application provider with authentication details.
# Usage
workato connections create [OPTIONS]
# Options
| --name TEXT | Name for the connection. |
| --provider TEXT | Application provider name. |
| --folder-id INTEGER | Folder ID where connection should be stored. |
| --input TEXT | JSON string with connection parameters. |
| --parent-id INTEGER | Parent connection ID for child connections. |
# Result
Creates new connection and returns connection ID and authentication status.
# Examples
Create Salesforce connection.
workato connections create --name 'Prod SF' --provider salesforceCreate connection with parameters.
workato connections create --name 'JIRA Prod' --provider jira --input '{"server_url":"https://company.atlassian.net"}'# workato connections create-oauth
Create OAuth-based connection by opening browser for user authentication flow.
# Usage
workato connections create-oauth [OPTIONS]
# Options
| --name TEXT | Name for the OAuth connection. |
| --provider TEXT | OAuth provider identifier. |
| --external-id TEXT | External identifier for runtime user connections. |
| --parent-id INTEGER | Parent connection ID for OAuth child connections. |
# Result
Opens browser for OAuth flow and creates authenticated connection upon completion.
# Examples
Create OAuth connection.
workato connections create-oauth --name 'Google Drive OAuth' --provider google_drive# workato connections get-oauth-url
Generates the OAuth authorization URL for establishing a new connection.
# Usage
workato connections get-oauth-url CONNECTION_ID [OPTIONS]
# Options
| --redirect-url | Custom redirect URL for OAuth callback. Optional. Uses default if not specified. |
# Result
Returns the OAuth authorization URL that users must visit to grant permissions and authenticate the connection.
# Examples
Get OAuth URL for a new Salesforce connection.
workato connections get-oauth-url 12345Generate OAuth URL with custom redirect.
workato connections get-oauth-url 12345 --redirect-url https://example.com/callback# workato connections update
Update existing connection properties such as name or configuration parameters.
# Usage
workato connections update [OPTIONS]
# Options
| --connection-id INTEGER | ID of the connection to update. |
| --name TEXT | New name for the connection. |
| --input TEXT | JSON string with updated connection parameters. |
# Result
Updates connection properties and returns confirmation of changes.
# Examples
Update connection name.
workato connections update --connection-id 123 --name 'Updated Connection Name'# workato connections pick-list
Retrieve dynamic pick list values from a connection for use in recipe configuration.
# Usage
workato connections pick-list [OPTIONS]
# Options
| --connection-id INTEGER | ID of the connection to query. |
| --object-name TEXT | Name of the object/pick list to retrieve. |
| --parameters TEXT | JSON parameters for the pick list query. |
# Result
Returns available pick list options that can be used in recipe field mappings.
# Examples
Get Salesforce objects.
workato connections pick-list --connection-id 123 --object-name sobjects# workato connectors list
List all available connectors in the Workato platform, including both standard and custom connectors.
# Usage
workato connectors list [OPTIONS]
# Options
| --custom | Show only custom connectors. |
# Result
Displays table of connectors with name, provider ID, authentication type, and availability.
# Examples
List all connectors.
workato connectors listShow only custom connectors.
workato connectors list --custom# workato connectors parameters
Show connection parameters and authentication requirements for specific connectors.
# Usage
workato connectors parameters [OPTIONS]
# Options
| --provider TEXT | Show parameters for specific provider or connector. |
| --oauth-only | Show only OAuth-enabled connectors. |
| --search TEXT | Search connector names. Case-insensitive). |
# Result
Displays connection fields, authentication methods, and configuration options.
# Examples
Show Salesforce connection parameters.
workato connectors parameters --provider salesforceFind OAuth connectors.
workato connectors parameters --oauth-only# workato data-tables list
List all data tables in the current workspace with schema and record count information.
# Usage
# Result
Displays table of data tables with ID, name, schema fields, and record counts.
# Examples
Show all data tables.
workato data-tables list# workato data-tables create
Create a new data table with specified schema for storing structured data in recipes.
# Usage
workato data-tables create [OPTIONS]
# Options
| --name TEXT | Name for the new data table. |
| --folder-id INTEGER | Folder ID where table should be created. |
| --schema-json TEXT | JSON schema definition for table fields. |
# Result
Creates new data table and returns table ID and schema confirmation.
# Examples
Create simple data table.
workato data-tables create --name 'Customer Data'Create table with schema.
workato data-tables create --name 'Products' --schema-json '[{"name":"product_id","type":"string","optional":false}]'# workato properties list
List environment or project properties that can be used in recipes for configuration management.
# Usage
workato properties list [OPTIONS]
# Options
| --prefix TEXT | Filter properties by name prefix, for example 'salesforce_'. |
| --project-id INTEGER | Show project-specific properties instead of environment properties. |
# Result
Displays properties with names, values (masked for sensitive data), and scope.
# Examples
List all properties.
workato properties listShow Salesforce-related properties.
workato properties list --prefix salesforce_# workato properties upsert
Create or update properties for environment or project-level configuration.
# Usage
workato properties upsert [OPTIONS]
# Options
| --project-id INTEGER | Target project for property updates. |
| --file TEXT | JSON file containing property key-value pairs. |
| --key-value TEXT | Single property in key=value format. |
# Result
Creates or updates properties and confirms changes made.
# Examples
Update property from file
workato properties upsert --project-id 123 --file properties.jsonSet single property
workato properties upsert --key-value api_endpoint=https://api.example.com# workato api-collections list
List API collections that expose recipes as REST endpoints for external consumption.
# Usage
workato api-collections list [OPTIONS]
# Options
| --per-page INTEGER | Number of collections per page. Default is 100. Maximum is 100. |
# Result
Displays API collections with ID, name, project, and endpoint count.
# Examples
List all API collections.
workato api-collections list# workato api-collections create
Create a new API collection to group and manage recipe endpoints.
# Usage
workato api-collections create [OPTIONS]
# Options
| --name TEXT | Name for the API collection Default is project name. |
| --project-id INTEGER | Project ID where collection should be created. |
# Result
Creates new API collection and returns collection ID and configuration details.
# Examples
Create API collection.
workato api-collections create --name 'Customer API'# workato api-collections list-endpoints
List all API endpoints within a specific collection showing their status and configuration.
# Usage
workato api-collections list-endpoints [OPTIONS]
# Options
| --api-collection-id INTEGER | ID of the API collection to examine. |
# Result
Displays endpoints with ID, name, HTTP method, path, and enabled status.
# Examples
Show endpoints in collection.
workato api-collections list-endpoints --api-collection-id 456# workato api-collections enable-endpoint
Enable a specific API endpoint to make it available for external API calls.
# Usage
workato api-collections enable-endpoint [OPTIONS]
# Options
| --api-endpoint-id INTEGER | ID of the API endpoint to enable. |
# Result
Enables the endpoint and provides the public URL for API access.
# Examples
Enable API endpoint.
workato api-collections enable-endpoint --api-endpoint-id 789# workato api-clients list
List API clients used for programmatic access to Workato APIs with their permissions and status.
# Usage
workato api-clients list [OPTIONS]
# Options
| --project-id INTEGER | Filter API clients by project ID. |
# Result
Displays API clients with ID, name, description, and permission scope.
# Examples
List all API clients.
workato api-clients list# workato api-clients create
Create a new API client for programmatic access to Workato APIs.
# Usage
workato api-clients create [OPTIONS]
# Options
| --name TEXT | Name for the API client. |
| --description TEXT | Description of the API client's purpose. |
| --project-id INTEGER | Project ID to associate with the client. |
# Result
Creates API client and returns client ID and initial access credentials.
# Examples
Create API client.
workato api-clients create --name 'Integration Client' --description 'For external system integration'# workato guide topics
List all available documentation topics in the integrated help system.
# Usage
# Result
Displays available help topics with descriptions and content summaries.
# Examples
Show all help topics.
workato guide topics# workato guide search
Search the integrated documentation for specific terms or concepts.
# Usage
workato guide search <QUERY> [OPTIONS]
| QUERY | Search terms to find in documentation. |
# Options
| --topic TEXT | Limit search to specific topic area. |
| --max-results INTEGER | Maximum number of results to return (default: 10) |
# Result
Returns relevant documentation sections with highlighted search terms.
# Examples
Search for connection help.
workato guide search 'oauth connection'Search within recipes topic.
workato guide search 'trigger' --topic recipes --max-results 5# workato guide content
Display the full content of a specific documentation topic.
# Usage
workato guide content <TOPIC>
| TOPIC | Name of the documentation topic to display. |
# Result
Shows complete documentation content for the specified topic.
# Examples
Show recipe documentation.
workato guide content recipes# workato assets
List all assets in the current workspace including recipes, connections, data tables, and folders.
# Usage
workato assets [OPTIONS]
# Options
| --output-format CHOICE | Output format: table (default) or json |
# Result
Displays comprehensive asset inventory with types, names, IDs, and folder locations.
# Examples
Show all assets.
workato assetsExport assets as JSON.
workato assets --output-format json# Environment Variables
The CLI supports the following environment variables:
- WORKATO_PROFILE: Default profile to use
- WORKATO_API_TOKEN: API token for authentication
- WORKATO_API_HOST: Custom API host URL
# Global Patterns
The following patterns apply across all CLI commands and provide consistent behavior for authentication, data handling, and error management.
# Authentication
All commands require authentication through:
- Profile configuration (recommended)
- Environment variables
- Command-line options
# Pagination
List commands support pagination with:
--page INTEGER: Page number (default: 1)--per-page INTEGER: Items per page (default varies, max: 100)
# Output Formats
Many commands support:
--output-format table: Human-readable table (default)--output-format json: Machine-readable JSON
# Error Handling
The CLI provides the following features to assist you with errors:
- Detailed error messages with context
- Suggestions for common issues
- HTTP status code information for API errors
- Validation feedback for malformed inputs
# Common Workflows
The following examples demonstrate typical workflows for getting started, developing recipes, managing connections, and working with APIs. These patterns can be combined and adapted to fit your specific requirements.
# Initial Setup
workato init # Interactive setup
workato workspace # Verify configuration
workato pull # Sync with workspace
# Development Cycle
workato recipes validate --path recipe.json
workato push --restart-recipes
workato recipes list --running
# Connection Management
workato connectors list --search salesforce
workato connections create --provider salesforce --name "Prod SF"
workato connections create-oauth --parent-id 123
# API Management
workato api-collections create --name "Customer API"
Last updated: 11/3/2025, 7:56:11 PM
