# Workato Platform CLI quick start
This guide walks you through the essential steps to get started with the Workato Platform CLI. You'll learn how to set up your environment, work with recipes and connections, and establish an efficient development workflow.
# Key development workflow
Initialize: Configure API credentials with workato init.
Manage Projects: Use workato project list and workato project use name.
Edit Recipes: Develop JSON recipe files locally.
Validate: Run workato recipes validate to check syntax.
Setup Connections: Create OAuth connections with workato connections create.
Deploy: Push changes with workato push.
Monitor: Show recipe executions with workato recipes jobs.
# Initial commands
Start using the Platform CLI with the following commands.
List available commands:
workato --help
List your recipes:
workato recipes list
List your connections:
workato connections list
List current project details:
workato workspace
# Example recipe workflow
Validate a recipe file.
workato recipes validate --path ./my-recipe.json
Push local files to your current Workato project.
workato push
Pull local files from your current Workato project.
workato pull
# Getting started recommendations
This section provides suggested initial actions for different roles.
# Individual developers
Complete the following steps for local-first development with validation and testing:
Configure your environment with workato init.
Use workato recipes validate for local development.
Set up profiles for your environments with workato profiles use NAME.
# Development teams
Development teams can use the Platform CLI for the following collaborative workflows with version control integration tasks:
- Establish shared project structures.
- Implement code review processes for recipes.
- Use CI/CD pipelines for deployments.
# Enterprise organizations
Enterprise organizations can use the Platform CLI for the following scalable automation with governance and monitoring tasks:
- Create standardized development workflows.
- Implement proper access controls and environments.
- Use monitoring and alerting for production systems.
Last updated: 11/3/2025, 7:56:11 PM
