Developer API - Event streams ​
The following endpoints enable you to manage event topics.
API DOMAIN AND NAMESPACE DIFFERENCES FOR EVENT STREAMS
The Event streams APIs are divided into two categories. Each category uses a different domain and namespace.
Public API ​
The following endpoints use the event-streams domain:
  • Consume messages POST /api/v1/topics/:topic_id/consume
  • Publish a message POST /api/v1/topics/:topic_id/publish
  • Publish a batch of messages POST /api/v1/batch/topics/:topic_id/publish
Refer to the Event streams public API documentation for more information.
Developer API ​
The following endpoints use the standard Developer API base URL:
  • List topics GET /api/event_streams/topics
  • Create a topic POST /api/event_streams/topics
  • Get a topic by ID GET /api/event_streams/topics/:topic_id
  • Update a topic PUT /api/event_streams/topics/:topic_id
  • Purge a topic PUT /api/event_streams/topics/:topic_id/purge
  • Delete a topic DELETE /api/event_streams/topics/:topic_id
Rate limits ​
Event streams developer API resources have the following rate limits:
TypeResourceQuota
AllAll Event streams endpoints60 requests per minute
Additionally, Event streams developer API resources have the following payload quota:
TypeResourceQuota
AllAll Event streams endpointsMaximum payload size:​ 1 MB
Quick reference ​
TypeResourceDescription
GET/api/event_streams/topicsRetrieve a list of topics.
POST/api/event_streams/topicsCreate a topic.
GET/api/event_streams/topics/:topic_idGet topic by ID.
PUT/api/event_streams/topics/:topic_idUpdate a topic.
PUT/api/event_streams/topics/:topic_id/purgePurge a topic.
DELETE/api/event_streams/topics/:topic_idDelete a topic.
BEST PRACTICE
For endpoints that modify topics (create and update), we recommend that you define parameters in the request body instead of the URL.
List topics ​
Retrieves a list of event topics, with optional filtering, sorting, and the ability to include topic schemas in the response.
GET https://YOUR_DATA_CENTER/api/event_streams/topics
Query parameters ​
NameTypeDescription
namestring
optional
Filters event topics by a case-sensitive title. Supports partial matching, which means you can search for fragments of the title.
sortstring
optional
Defines how to sort the results. Options include activity (most recent activity first), name, and id. Set to id by default.
include_schemaboolean
optional
When set to true, the schema of each event topic is included in the response payload. Set to false by default.
Sample request ​
This request retrieves event topics that contain the keyword Order within the name. The results are sorted by event topic ID, and the schema for each event topic is included in the response payload.
shell
curl  -X GET "https://YOUR_DATA_CENTER/api/event_streams/topics?name=:name_value&sort=:sort_value&include_schema=:include_schema_value" \
Response ​
json
    "count": 2,
    "data": [
            "id": 334525,
            "name": "Order placed",
            "folder_id": 986754,
            "created_at": "2024-09-25T09:47:54.089-07:00",
            "updated_at": "2024-09-25T09:47:54.089-07:00",
            "retention": 604800,
            "schema": [
                    "control_type": "text",
                    "label": "Order ID",
                    "name": "OrderId",
                    "optional": false,
                    "type": "string"
                    "label": "Customer ID",
                    "name": "CustomerId",
                    "optional": false,
                    "type": "string"
                    "label": "Amount",
                    "name": "Amount",
                    "optional": false,
                    "type": "string"
                    "control_type": "date",
                    "label": "Order date",
                    "name": "OrderDate",
                    "optional": false,
                    "parse_output": "date_conversion",
                    "render_input": "date_conversion",
                    "type": "date_time"
            "description": "Triggered when a new order is placed."
            "id": 334526,
            "name": "Order shipped",
            "created_at": "2024-09-25T09:51:12.130-07:00",
            "updated_at": "2024-09-25T09:51:12.130-07:00",
            "schema": [
                    "name": "OrderId",
                    "optional": false,
                    "type": "string"
                    "label": "Shipping carrier",
                    "name": "ShippingCarrier",
                    "optional": false,
                    "type": "string"
                    "label": "Tracking number",
                    "name": "TrackingNumber",
                    "optional": false,
                    "type": "string"
                    "label": "Shipped date",
                    "name": "ShippedDate",
                    "optional": false,
                    "type": "date_time"
            "description": "Triggered when an order is shipped."
Create a topic ​
Creates a new event topic.
POST https://YOUR_DATA_CENTER/api/event_streams/topics
NameTypeDescription
namestring
required
The name of the new topic. Topic names must be unique within a folder.
folder_idnumber
optional
The ID of the folder or project to store the topic inside. By default, Workato places the topic in your workspace's Event Streams project, creating that project if it doesn't already exist.
schemaarray
required
The schema definition for the new topic. Must adhere to a valid Workato schema format.
schema[control_type]string
required
The control type for a field in the topic schema.
schema[label]string
required
The label that appears for the field in the topic schema.
schema[name]string
required
The name identifier for the field in the topic schema.
schema[optional]boolean
required
Specifies whether the field is optional.
schema[type]string
required
The data type of the field in the schema.
retentionnumber
optional
Retention time for the topic in seconds. Defaults to 168 hours (604,800 seconds) if not specified.
descriptionstring
optional
A description of the new topic.
DEFAULT ACCESS FOR API TOPICS
Topics that you create through the Developer API are accessible only to the workspace owner by default. The workspace owner grants access to other collaborators by adding them to the project that contains the topic and assigning a project role that includes the Event streams privilege.
Sample request ​
This request creates a new event topic named Order delivered. The topic includes details such as the order ID, delivery date, and optional information about the person or service delivering the order.
shell
curl  -X POST "https://YOUR_DATA_CENTER/api/event_streams/topics" \
      -d '{
            "name": ":name",
            "schema": [
                    "control_type": ":control_type",
                    "label": ":label",
                    "name": ":schema_name",
                    "optional": :true_or_false,
                    "type": ":type"
            "retention": :retention_value,
            "description": ":description"
Response ​
json
    "data": {
        "id": 334527,
        "name": "Order delivered",
        "created_at": "2024-09-25T09:56:32.986-07:00",
        "updated_at": "2024-09-25T09:56:32.986-07:00",
        "schema": [
                "name": "OrderId",
                "optional": false,
                "type": "string"
                "label": "Delivery date",
                "name": "DeliveryDate",
                "optional": false,
                "type": "date_time"
                "label": "Delivered by",
                "name": "DeliveredBy",
                "optional": true,
                "type": "string"
        "description": "Triggered when an order is delivered."
Folder not found ​
The request fails and returns the following response if you supply a folder_id that doesn't exist:
json
    "message": "Folder not found"
Get topic by ID ​
Retrieves an event topic by its ID.
GET https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id
URL parameters ​
NameTypeDescription
topic_idnumber
required
The ID of the event topic to retrieve.
Sample request ​
This request retrieves the Order delivered event topic by its unique :topic_id.
shell
curl  -X GET "https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id" \
Response ​
json
    "data": {
        "id": 334527,
        "schema": [
                "name": "OrderId",
                "optional": false,
                "type": "string"
                "optional": false,
                "type": "date_time"
                "optional": true,
                "type": "string"
Update a topic ​
Updates an event topic.
PUT https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id
URL parameters ​
NameTypeDescription
topic_idnumber
required
The ID of the event topic to update.
NameTypeDescription
namestring
optional
The name of the updated topic.
folder_idnumber
optional
The ID of the folder or project to move the topic to. By default, Workato places the topic in your workspace's Event Streams project, creating that project if it doesn't already exist.
schemaarray
optional
The schema definition for the updated topic. Must adhere to a valid Workato schema format.
optional
schema[label]string
optional
schema[name]string
optional
optional
schema[type]string
optional
retentionnumber
optional
descriptionstring
optional
A description of the updated topic.
Sample request ​
This request updates the topic schema for the Order delivered event topic by adding a new field named Recipient.
shell
curl  -X PUT "https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id" \
      -d '{
            "name": ":name",
            "schema": [
                    "label": ":label",
                    "type": ":type"
Response ​
json
    "data": {
        "id": 334527,
        "schema": [
                "name": "OrderId",
                "optional": false,
                "type": "string"
                "optional": false,
                "type": "date_time"
                "optional": true,
                "type": "string"
                "label": "Recipient",
                "name": "Recipient",
                "optional": false,
                "type": "string"
Folder not found ​
json
Purge a topic ​
Erases all messages from the event topic's history and resets topic statistics.
PUT https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id/purge
NameTypeDescription
topic_idnumber
required
The ID of the event topic to purge.
Sample request ​
This request erases all messages from the Order delivered event topic's history and resets topic statistics.
shell
curl  -X PUT "https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id/purge" \
Response ​
json
    "data": {
        "status": "success"
Delete a topic ​
Deletes an event topic.
DELETE https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id
URL parameters ​
NameTypeDescription
topic_idnumber
required
The ID of the event topic to delete.
Sample request ​
This request deletes the Order delivered event topic.
shell
curl  -X DELETE "https://YOUR_DATA_CENTER/api/event_streams/topics/:topic_id" \
Response ​
json
    "data": {
        "status": "success"
