# Return data to component action
Use the Return data to component action to return data back to a component in a Workflow app. This action must be used in combination with the New component event, New component event (Table widget), or New component event (drop-down) trigger. The recipe job stops immediately after this action.
| Consider action as successful? | Use the Consider action as successful? drop-down to determine whether the action was completed successfully. |
| Output | Map in recipe datapills to return data to a page component. The fields in this section are dynamic and determined by the Output schema defined in the trigger. |
| Successful toast message | Optional. Provide a successful toast message to display to end-users if the action completes successfully. If left blank, no toast message is displayed to users. |
| Error message | Optional. Provide a custom error message to display to end-users if the action fails. If left blank, no error message is displayed to users. |
| Successful toast message | The message that displays to end-users when the action completes successfully. |
| Error message | The message that displays to end-users when the action fails. |
| Output | The data returned to the Workflow app component. This object is dynamic and the output depends on the datapills mapped into the action input. |
Last updated: 8/27/2025, 1:04:58 AM
