# Callable Recipes
Callable recipes are a type of recipe that can be called from another recipe. This helps to reduce the length of your recipes by separating a repeatable set of actions into a callable recipe that can be called from other recipes that require the same steps.
THIS CONNECTOR IS DEPRECATED
On December 3, 2021, the Recipe functions and API platform connectors replaced s.
Existing callable recipes continue to work, but you can't create new ones..
Check out the migration guide, Recipe functions FAQ, and API recipes FAQ for more info.
A callable recipe is triggered by a call from another recipe instead of a trigger event in an application.
Callable recipes can also be exposed as REST endpoints using the API Platform feature.
# Advantages of using callable recipes
| Advantages | Details |
| Easier to test | By grouping a set of actions into a separate recipe instead of repeating them in the same recipe, you reduce the effort needed to change and test the steps. |
| More readable | Instead of having really long recipes, break it out into smaller recipes that can be called. |
| Sharing across recipes | If you have a standard error notification policy, you can create a recipe and then have all recipes call this recipe for error notification. |
| Share across accounts and with partners | You can expose REST APIs to your business partners. For example, a REST API that provides inventory status to your suppliers. |
Last updated: 10/23/2025, 8:27:15 PM
