# Create Zendesk and Jira issues with Workbot for Slack recipe
This use case guides you through connecting Zendesk, Jira, and Workbot for Slack to Workato to create a powerful automation.
# What does this recipe do?
This recipe enables you to execute a message action in Workbot for Slack, which creates a Zendesk ticket and a Jira issue using the input fields from the trigger's command. After creating these tickets, the details are posted in Slack to a channel or direct message of your choice.
# Create your recipe
Complete the following steps to design a recipe that creates a Zendesk ticket and a Jira issue when you run an action command in Workbot for Slack.
Sign in to Workato.
Create connections for Zendesk, Jira, and Workbot for Slack:
Create a Zendesk connection.
# Create a Zendesk connection
This step creates a connection between Workato and your Zendesk account.
Click Create > Connection.
Search for and select Zendesk on the New connection page.
Zendesk connection setup
Enter the Subdomain for your Zendesk URL. For example, if your Zendesk URL is https://acme.zendesk.com, your subdomain is acme.
Use the Authentication type drop-down menu to select the authentication type you plan to use for your connection.
Optional. Provide your Custom OAuth profile.
Create a Jira connection.
# Create a Jira connection
This step creates a connection between Workato and your Jira account.
Search for and select Jira on the New connection page.
Enter a name for your Jira connection in the Connection name field.
Jira connection setup
Select your Connection type.
Use the Auth type drop-down menu to select your authentication method. Supported options include Basic, API token, OAuth 2.0, and Personal access token.
Provide your Host name. For example, if your Jira URL is https://acme.atlassian.net, your host name is acme.atlassian.net.
Create a Workbot for Slack connection.
# Create a Workbot for Slack connection
This step creates a connection between Workato and your Workbot for Slack account.
Search for and select Workbot for Slack on the New connection page.
Provide a name for your connection in the Name field.
Workbot for Slack connection setup
Optional. Select the NLU provider you plan to use, such as DialogFlow or Amazon Lex NLU. You must connect to the NLU provider for it to appear in the drop-down menu.
Optional. Click Advanced to configure Slash commands verification tokens, custom help content, your Slack app status (classic or not), and your Custom OAuth profile.
Click Connect, sign in to your Slack workspace when prompted, and click Continue to verify the connection.
Go back to your project and click Create > Recipe.
Create a new recipe
Click Start building.
Start building your recipe
Set up your Workbot for Slack New shortcut trigger.
# Set up Workbot for Slack New shortcut trigger
This trigger monitors Workbot for Slack for new shortcuts.
Search for Workbot for Slack and select it as your app.
Choose Workbot for Slack as your app
Select the New Shortcut trigger.
Use the Shortcut type drop-down menu to select Message.
Set up your Shortcut trigger
Enter a name in the Shortcut name field. For example, Create issue & ticket.
Click Add field in the Parameters section.
Enter Summary in the Name field.
Enter a label in the Label field.
Select String from the Data type drop-down menu.
Select No from the Optional? drop-down menu.
Enter additional help text in the Hint field.
Select Text from the Dialog control type drop-down menu.
Summary input field
Click Add field under Parameters to add a second input field.
Enter Description in the Name field.
Select Textarea from the Dialog control type drop-down menu.
Description input field
Click Add field under Parameters to add a third input field.
Enter Priority in the Name field.
Enter additional help text in the Hint drop-down menu.
Select Static from the Menu options drop-down menu.
Enter a list of comma-separated priority levels in the Options field.
Priority input field
Click the Add field button under Parameters to add a fourth input field.
Name your input field notify-user > add a Label > set Data type to String > set Optional? to No > provide a Hint for your input field > set Menu options to Conversations > and then click Save.
notify_user input field
Use the Copy original text into dialog field drop-down menu to select Description.
Select Description
Click Save.
Click Add step > Add action in app
Set up your Jira Create issue action.
# Set up Jira Create issue action
This step creates a new issue in Jira and uses the description from Workbot for Slack.
Search for Jira and select it as your app.
Choose Jira as your app
Select the Create issue action.
Use the Project issue type drop-down menu to select the issue type you plan to create. For example: task, bug fix, or onboarding.
Select your issue type
Map the Workbot for Slack Summary Step 1 datapill to the Summary field.
Map the Workbot for Slack Description Step 1 datapill to the Description field.
Map the Workbot for Slack Priority Step 1 datapill to the Priority name field.
Click Save.
Set up your Jira Get issue action.
# Set up Jira Get issue action
This steps retrieves Jira issues by ID.
Select the Get issue action.
Map the Jira ID Step 2 datapill to the Issue ID or key field.
Configure the Issue ID or key field
Click Save.
Set up your Zendesk Create ticket action.
# Set up Zendesk Create ticket action
This step creates a Zendesk ticket with information from Jira and Workbot for Slack.
Search for Zendesk and select it as your app.
Choose Zendesk as your app
Select the Create ticket action.
Map the Jira Summary Step 3 datapill to the Subject field.
Use the Priority drop-down menu to select Enter custom value and then click Formula.
Set the Priority field to Formula
Copy and paste the following formula into the Priority field:
=["Higher", "Highest"].include?(_dp('{"pill_type":"output","provider":"jira","line":"9e7af602","path":["fields","priority","name"]}')) ? "urgent" : "Medium" == _dp('{"pill_type":"output","provider":"jira","line":"9e7af602","path":["fields","priority","name"]}') ? "normal" : _dp('{"pill_type":"output","provider":"jira","line":"9e7af602","path":["fields","priority","name"]}') == "High" ? "high" : "low"
Priority formula
Use the Status drop-down menu to select Open.
Map the Jira Due date Step 3 datapill to the Due at field.
Configure the Due at field
Map the Workbot for Slack Description Step 1 datapill to the Text comment field.
Configure the Text comment field
Click Save.
Set up your Workbot for Slack Post message action.
# Set up Workbot for Slack Post message action
This step posts a Slack message notify the users and channels you specify about the new Zendesk ticket.
Select the Post message action.
Map the Workbot for Slack Notify user Step 1 datapill to the Channel name/DM field.
Configure the Channel name/DM field
Click Add block to message and use the Type drop-down menu to select Section with text.
Click the Add block to message button
Map the Zendesk Subject Step 4 datapill, the Zendesk Ticket ID Step 4 datapill, and the Workbot for Slack User ID Step 1 datapill to the Section text field.
Map the Section text field
Click Add block to message and use the Type drop-down menu to Section with fields.
Section with fields
Locate the Attachment fields section and click Add field.
Enter Subject in the Title field.
Map the Zendesk Subject Step 4 datapill to the Value field.
Add a Subject field
Click Add field to add a second field.
Enter Priority in the Title field.
Map the Zendesk Priority Step 4 datapill to the Value field.
Click Add field to add a third field.
Enter Description in the Title field.
Switch the Value field to formula mode and copy and paste the following formula:
="\n"+_dp('{"pill_type":"output","provider":"zendesk","line":"create_ticket","path":["description"]}')[0...65]+"..."
Add a Description field
Click Add field to add a fourth field.
Enter Status in the Title field.
Map the Zendesk Status Step 4 datapill to the Value field.
Expand the Divider section and use the Type drop-down menu to select Divider.
Select Divider
Click Save.
Set up your second Workbot for Slack Post message action.
# Set up a second Workbot for Slack Post message action
This step posts a Slack message notify the users and channels you specify about the new Jira issue.
Map the Workbot for Slack Notify user Step 1 datapill into the Channel name/DM field.
Click Add block to message and use the Type menu to select Section with text.
Map the Jira Key Step 3 datapill and the Workbot for Slack User ID Step 1 datapill to the Section text field.
Map the Section with text field
Click Add block to message and use the Type drop-down menu to select Section with fields.
Enter Summary in the Title field.
Map the Jira Summary Step 3 datapill to the Value field.
Add a Summary field
Enter Priority in the Title field,
Map the Jira Name Step 3 datapill to the Value field.
="\n"+ _dp('{"pill_type":"output","provider":"jira","line":"9e7af602","path":["fields","description"]}')[0...65]+"..."
Click Save.
Your Create Zendesk and Jira issues with Workbot for Slack recipe is ready to test and implement.
Last updated: 10/14/2025, 5:37:34 PM
