# Alerts and monitoring
Workato provides detailed transfer logs, run history, performance analytics, and configurable notifications to enhance visibility into file transfer operations.
# Run history and analytics
The Runs tab of a file transfer asset provides a historical view of transfers with the following capabilities:
  • Use the search bar to search file names.
  • Use the Period and Status drop-down menus to filter logs.
  • Click Retry on a failed row to retry a single transfer or click Retry all failed to retry all failed transfers.
  • Select a row to view its detailed transfer log.
The Runs tabThe Runs tab
# Transfer logs
You can select a row in the Runs tab to view its transfer log. Transfer logs record the complete lifecycle of each file transfer operation, starting at file detection and ending at post-processing.
Transfer logs provide the following capabilities:
  • Use the search bar to search within the timeline.
  • Click Retry to retry a failed transfer.
  • Click Download to download the original file, if available.
Each transfer log timeline contains the following information:
A successful transfer logA successful transfer log
Transfer log example
The following example shows the log for a successfully completed transfer:
[02:45:42] FILE_DETECTED_AT_SOURCE
Source: Workato FileStorage
File: /outbound/banking/partner-a/bankB_report_20250826.csv
File size: 1.5GB
Filter: report_*.csv
[02:45:43] SOURCE_TRANSFER_STARTED
Progress: 100%
[02:45:45] SOURCE_TRANSFER_COMPLETE
Duration: 2.17s
[02:46:00] PROCESSING_STARTED
Pipeline: 3 actions
[02:46:00] ACTION_1_ENCRYPTION
Status: PGP Encryption complete
[02:46:00] ACTION_2_COMPRESSION
Status: GZIP compression complete (1.5GB → 650MB)
Output file: bankB_report_20250830_093045.pgp.gz
[02:46:00] ACTION_3_RENAMING
[02:46:02] TARGET_TRANSFER_STARTED
Target: partner-a-sftp.bank.com:22
Progress: 100%
[02:49:39] TARGET_TRANSFER_COMPLETED
Duration: 3m 37s
# Notifications
MFT allows you to configure email notifications for individual file transfer flows to monitor specific events.
Complete the following steps to configure email notifications for a file transfer:
Select the File transfer asset you plan to monitor.
Go to Settings > Notifications.
Notification settingsNotification settings
Optional. Enter a comma-separated list of email addresses to notify in the Recipient field. Defaults to the project admin's email address if left blank.
Optional. Leave Transfer runs enabled to receive an email when a transfer fails all retry attempts and moves to the error queue. This setting is On by default.
Optional. Enable the Successful runs toggle to receive an email when target delivery is confirmed and post-processing completes. This setting is Off by default.
Optional. Enable the Transfer inactivity toggle to receive an email when a transfer doesn't run within 30 minutes of the expected schedule. This setting is Off by default.
Click Save.
# Best practices
Workato recommends the following best practices for transfer flow notifications:
Failure notifications: Enable failure notifications for production transfers to catch issues quickly.
Success notifications: Enable success notifications only for critical transfers to avoid inbox overload. Most transfers succeed routinely.
Inactivity notifications: Enable inactivity notifications for time-sensitive transfers where missing a schedule indicates upstream system issues.
Multiple recipients: Include the operations team and relevant stakeholders in the Recipient field.
FEATURE AVAILABILITY
Contact your Customer Success Manager for information about access to Workato MFT.
Last updated: 11/19/2025, 5:53:42 PM
