Partner Connectors ​
Whilst many partners are already building and listing their connectors on the community, Partner connectors represent the next step up from community connectors. Partner connectors refers to connectors that are published at the same level as Workato's natively built connectors like Salesforce, Workday and NetSuite, except they are built and maintained by Workato's trusted ISV partners. In contrast from community connectors, there is no need to install Partner connectors before you can use them.
DEPRECATION NOTICE
The Partner Connectors program is deprecated. Workato no longer hosts partner-built connector code in its GitHub organization. Partners should instead use closed-source SDK connector sharing to distribute and promote their connectors securely.
All partner-built connectors must follow the SDK connector guidelines and be published through the Connector SDK using the private or community sharing options.
This page remains available for legacy reference only.
Where can I find and distinguish Partner connectors? ​
Partner connectors can be found in the Recipe editor or the new connections page alongside other platform connectors. Partner connectors will have a "Partner" badge displayed prominently on the app logo, indicating to you that these are built and maintained by Workato's partners.
Partner connector badge
How do I use Partner connectors? ​
Partner connectors can be used similar to any other platform connector in Workato. When selecting a partner connector for the first time, you will see a modal that provides some additional details about the partner such as the name of the organization that built the connector. When you use Partner Connectors, you agree to our Community policy regarding usage of Partner Connectors.
Partner connector modal
How are Partner Connectors vetted? ​
Partner connector code is reviewed by Workato engineers for both security and code quality to ensure that these connectors are safe to use. Each new update to the connector is follow the same review process to ensure stability and performance.
These connectors are also publicly available for review on Github under our public Workato Partners organization.
How should you get support for Partner Connectors you are using in your recipes? ​
You may reach out to the partner's support if you have an existing relationship. If not, you may log a support ticket with Workato which will route it to the partner as well. Do take note that Workato cannot enforce the same SLAs in terms of response times, bug fixes and enhancements that we do for our native connectors.
How can I contribute a Partner Connector? ​
The Partner connectors program is currently invitation only. We plan to extend this capability to more partners, with priority given to partners who are also owners of the APIs behind the connectors they have built as well as those who have gained significant traction in terms of installs when publishing their connector to the community. In the interim, please consider listing your connector on our community.
