# ELT Pipeline for Snowflake accelerator - Assets - Lookup tables
The ELT Pipeline for Snowflake accelerator has seven lookup tables that are common to both Slack and Microsoft Teams implementations of the accelerator:
# ELT | User Access
The ELT | User Access lookup table contains the following fields:
Email
The user's email address.
Active
The pipeline's status.
Pipelines Pinned
The pipelines the user has pinned to their App homepage.
Role
The user's role. Admin or Analyst.
# ELT | Systems
The ELT | Systems lookup table contains the following fields:
SYSTEM_ID
References the SYSTEM_ID in the ELT | Systems lookup table.
SYSTEM
The source system.
TYPE
The type of application (source).
CREATED_BY
The email address of the person who created the object.
CREATED_ON
Date when the object was created.
# ELT | Objects
The ELT | Objects lookup table contains the following fields:
SYSTEM_ID
OBJECT
The object used for the pipeline.
CREATED_BY
CREATED_ON
PRIMARY_KEY
Custom Primary Key for SQL-type sources.
# ELT | JOB TABLE
The ELT | JOB TABLE lookup table contains the following fields:
ELT_CONTROL_ID
Unique ID auto-generated when you create a pipeline. This ID corresponds to the ELT_CONTROL_ID in the **ELT | CONTROL TABLE | MAIN** lookup table.
JOB_ID
Unique Job ID of the running pipeline.
BATCH_START_DT
Start date-time of the job.
BATCH_END_DT
End date-time of the job.
ROWS_AFFECTED
Total Rows processed. (Salesforce only)
IS_SUCCESS
This value indicates whether the job was successful. Boolean value (true/false).
DISPATCHER_JOB_URL
Job URL of the evaluated workload.
WORKLOAD_JOB_URL
Job URL of the respective workload called by the dispatcher.
# ELT | ERROR LOGS
The ELT | ERROR LOGS lookup table contains the following fields:
ELT_CONTROL_ID
Unique ID auto-generated when you create a pipeline. This ID corresponds to the ELT_CONTROL_ID in the ELT | CONTROL TABLE | MAIN lookup table.
JOB_ID
ERROR_MSG
Error message on failure.
ERROR_CODE
Error code of failure. Use to determine reprocessing logic.
JOB_URL
URL of the failed job.
ACTION
Dependent on the error code. Use to determine reprocessing logic. Actions can include notifications.
# ELT | CONTROL TABLE | MAIN
The ELT | CONTROL TABLE | MAIN lookup table contains the following fields:
ELT_CONTROL_ID
SOURCE_SYSTEM_NAME
Source system where the data originates.
SOURCE_OBJECT_NAME
Name of the desired data entity. This is usually a table or file name in the case of file source systems.
TARGET_TABLE_NAME
The table where the accelerator loads the data.
LOAD_TYPE
Type of the load.
Allowed values:
Full, incremental, or extract.
STATUS
Pipeline status.
Allowed values:
Pending, Active, Inactive, Error, Processing, or Extract
COMM
Communication channel (Slack or Microsoft Teams)
CREATED_BY
Email of the user who created the pipeline.
UPDATED_BY
Email of the user who updated the pipeline.
# ELT | CONTROL TABLE | CHILD
The ELT | CONTROL TABLE | CHILD lookup table contains the following fields:
ELT_CONTROL_ID
PIPELINE_CREATED_DT
Date when the pipeline is created.
PIPELINE_UPDATED_DT
Date when the pipeline is updated.
HOUR
Hour of the day selected.
MINUTE
Minute of the hour of the day selected.
FREQUENCY
How frequently the pipeline runs.
Allowed values:
Daily, Weekly, Monthly, Hourly, or Yearly
START_TIME
The time when the user schedules the pipeline to start.
NEXT_TIME
The next time the pipeline must run.
LAST_SUCCESSFUL_JOB_URL
Jobs are sub-tasks in a pipeline. The accelerator records them on the first and subsequent runs. The accelerator updates this value when a job finishes successfully.
LAST_SUCCESSFUL_JOB_DT
Last time the job ran successfully.
