AgentX Support - Set up Zendesk email and ticket automation
AgentX Support can automate responses and actions for Zendesk tickets using AI. The automation engine analyzes incoming tickets and responds using macros, email templates, and relevant knowledge base articles.
Prerequisites
Before configuring the Zendesk automation, complete the following in AgentX Support:
  • Establish an OAuth 2.0 connection with your Zendesk instance.
  • Create an AI agent and flows to define actions for the agent to take.
Execution flow
The following diagram illustrates how the automation flow works:
Zendesk configuration
Complete the following configuration steps within your Zendesk instance to set up the Zendesk automation with AgentX Support:
Create a webhook in Zendesk
Create a webhook to send ticket events to AgentX Support.
You can find the webhook URL in the Channels section of AgentX Support.
Create a trigger in Zendesk
Add a trigger to inform AgentX Support when a ticket is created or updated.
Go to Zendesk Admin Center > Objects and Rules > Triggers.
Click Add Trigger.
Configure the trigger as follows:
Name: AgentX Support Automation
Conditions:
Meet all of the following:
  • Tags does not contain dc-automation-triggered
  • Ticket is Updated
Meet any of the following:
  • Channel is Email (Add any other channels that you plan the trigger to run for)
Actions:
  • Notify active webhook: AgentX Support Automation
JSON Body:
json
  "agent": {
    "name": "{{ticket.assignee.name}}",
    "email": "{{ticket.assignee.email}}"
  "requester": {
    "name": "{{ticket.requester.name}}",
    "email": "{{ticket.requester.email}}"
  "payload": {
    "id": "{{ticket.id}}",
    "source": "{{ticket.via}}",
    "title": "{{ticket.title}}",
    "description": "{{ticket.description}}",
    "status": "{{ticket.status}}",
    "message": "{{ticket.latest_comment}}",
    "tags": "{{ticket.tags}}",
    "updated_stamp": "{{ticket.updated_at_with_timestamp}}",
    "brand": "{{ticket.brand.name}}",
    ... custom fields
    "marketplace": "{{ticket.ticket_field_8792255150861}}"
Add tags: dc-automation-triggered
Save the trigger and return to the Triggers list.
Reorder and sort triggers
Make sure that the automation trigger is ordered after any business rule triggers that update the ticket to ensure that AgentX Support receives all the required ticket data.
Refer to the Zendesk documentation for more information on reordering triggers.
Tags used by AgentX Support
TagDescription
dc-automation-triggeredIndicates the ticket passed through the AgentX Support automation webhook.
dc-auto-replyIndicates that an auto-reply was added to the ticket.
dc-automation-ticket-updatedIndicates that the automation updated certain fields on the ticket.
dc-email-positive-feedbackMarks positive customer feedback on the auto-reply.
dc-email-negative-feedbackMarks negative customer feedback on the auto-reply.
