# API endpoint caching
WHO CAN USE THIS FEATURE?
To use this feature, you need the following:
- Access to the API Platform feature
- The API platform privilege
At its core, Workato helps streamline your business operations. The API caching feature adds an additional layer of optimization by reducing the number of identical requests that recipes have to make. For you, this has the following direct advantages:
- Faster response times in recipe actions
- Decrease in the total number of jobs
- Decreased job duration
- Reduction in traffic between applications
In this guide, we cover the following scenarios:
- How API caching works
- How long cache data is retained
- Caching using endpoint parameters
- Caching best practices
- Caching limits and quotas
- How to enable caching for endpoints
- How to clear cached entries
- How to re-validate cached entry
# How it works
When enabled, API caching temporarily stores responses in a cache. Subsequent requests sent to the same endpoint (if sent within a specified amount of time) retrieve stored data from the cache, without utilizing the recipe endpoint. This results in faster response times and less resource usage.
# Caching basics
Here is a brief overview of API caching:
- Caching is set on a per-endpoint basis
- Only GET methods support caching
- Each response to a GET request is a cache entry. Cache entries have size and workspace-specific limits.
- Cache entries are retained for a defined time period
- Caching supports using path and query string parameters
# Cache retention
When you set up caching for an endpoint, you can define the amount of time that the cache retains each entry. Subsequent requests sent during the retention period - or Time-to-live - retrieve the entry from the cache instead of reading the endpoint again.
When the retention period ends, the cache automatically flushes the entry.
For example: If the retention period is set to 600 seconds - or 10 minutes - entries remain in the cache for 10 minutes, and then are automatically flushed.
Each user ID has a cache limit of 10,000 entries. When this limit is reached, the oldest entries are flushed to accommodate newer entries.
# Caching using path and query string parameters
In addition to defining the retention period for cached entries, you can also define path and query string parameters to use as a cache key. If the cache key matches a request during the retention period, the request returns the matching entry from the cache.
All path and query string parameters can be included in the cache keys.
Example using path parameters
Let's say our endpoint is /users/{id}, where ID is a value like 12345. If a request is sent that matches the following example, the cached entry for user id: 12345 will be returned from the cache:
curl -X GET https://api.myworkatoexample.com/docs/users/12345 \
-H 'API-TOKEN: YOUR_TOKEN'
Example using query strings
Let's say our endpoint is /users?id={value}, where the ID is a value like 12345. If a request is sent that matches the following example, the cached entry for user id: 12345 will be returned from the cache:
curl -X GET https://api.myworkatoexample.com/docs/users?id=12345 \
# Best practices
We recommend using caching on record types that don't change frequently. This reduces the likelihood of an outdated version of a record being retrieved from the cache.
Cached entries can be manually cleared before the retention period ends, if needed.
# Limits and quotas
Only successful GET requests that return a 2xx status code can be cached.
| Description | Limit | Notes |
| Maximum cache key size | 10 kB | NA |
| Maximum cache entry value size | 10 kB | Requests exceeding this limit do not cache even when successful. Contact your Workato Customer Success Manager to adjust this limit. |
| Maximum cache entry count per user ID | 10,000 entries | If exceeded, entries are flushed, from oldest to newest, to accommodate new entries. To adjust this limit, contact your Workato Customer Success Manager for support. |
| API response and cache limits | 100 KB | NA |
# Enabling endpoint caching
Caching can be enabled for new and existing GET endpoints. If starting from scratch, follow the steps in the Create the recipe endpoint section before proceeding.
Click Edit response.
Toggle Cache response to on.
In the Time-to-live period field, define the time in seconds. This is how long the responses are stored in cache before being refreshed or deleted. The default to 600 seconds, or 10 minutes. The maximum is 3600 seconds (60 minutes).
In the Cache key parameters field, select the key(s) to use in request matching.
When finished, click Add endpoint.
Endpoints with caching enabled have the Cache enabled badge:
# Monitoring endpoint caching
To view details about cached responses, navigate to API platform > Logs. A request that used a cached response has a Cached badge next to its Response time value.
# Clearing cached endpoint data
Cached entries clear automatically, based on the retention period you define. You can also manually clear the endpoint's entire cache.
Go to Platform > API platform > API collections.
Click the collection that contains the endpoint you plan to clear.
On the collection page, locate the endpoint.
Click the ... (more) menu on the right side of the endpoint.
Click Clear cached responses.
When prompted to confirm, click Clear cache.
# Re-validate cached entry
Occasionally, clients decide to request the latest state by instructing the platform to re-validate the cached entry. To do this, send a request with Cache-Control: max-age=0 header.
curl https://api.myworkatoexample.com/docs/users/12345 \
-H 'Authorization: Bearer ACCESS_TOKEN' \
-H 'Cache-Control: max-age=0'
Last updated: 10/7/2025, 10:58:02 PM
