# API collections
An API collection is a group of API endpoints that share a common access pattern. You can use collections to manage endpoints together. For example, group Salesforce endpoints used by Sales team recipes into one collection.
The API collections page displays all API collections within a workspace. Go to Platform > API platform > API collections to access the API collections page.
SUMMARY
- API collections group endpoints with a shared access pattern.
- Each collection is created as a recipe, proxy, or AI gateway collection, which determines how you define and manage its endpoints.
- Collections include OpenAPI v3.0 documentation and support syncing to Postman.
# Collection types
There are three types of API collections:
- API proxy collection: Forwards requests to your existing backend with minimal processing. Deploy to the Workato cloud gateway or an Edge Gateway for on-prem processing.
- API recipe collection: Uses Workato recipes to define custom logic and expose it as API endpoints.
- AI gateway collection: Exposes endpoints to LLMs or GPTs for secure AI-driven automation.
# Choose a collection type
Choose a collection type based on how you plan to expose or build your backend.
The right mix of proxy, recipe, and AI gateway collections helps you optimize your API platform (opens new window) usage.
Use the following diagram to determine which type of API collection fits your use case:
# Sync to Postman
You can sync an API collection to Postman to increase visibility and encourage adoption across internal and external developer communities.
Refer to Sync to Postman for more information.
Last updated: 4/22/2026, 3:28:51 PM
