Active Directory - New entry trigger
The New entry trigger monitors Active Directory for newly created entries.
Input
Input fieldDescription
Sample entry DNSpecify the distinguished name (DN) of a reference entry. The trigger uses this entry's attributes as a template to retrieve values from newly created entries.
When first started, this recipe should pick up events fromSet the date and time to start picking up trigger events. This enables your recipe to capture past events. Refer to Triggers to learn more about this input field.
LimitEnter the maximum number of entries you plan to retrieve for each trigger event. The maximum value is 1,000 entries.
Entry search filterEnter LDAP filters to add conditions that newly created entries must meet to trigger a job. For example, enter (ou=Dev)(objectClass=Person) to retrieve only Person entries from the Dev organization unit.
Output
The New entry trigger's output includes values from the newly created entry for each attribute defined by the reference entry.
