# Active Directory - New/updated entry trigger
The New/updated entry trigger monitors Active Directory for newly created or updated entries.
Input field Description
Sample entry DN Specify the distinguished name (DN) of a reference entry. The trigger uses this entry’s attributes as a template to retrieve values from newly created or updated entries.
When first started, this recipe should pick up events from Set the date and time to start picking up trigger events. This enables your recipe to capture past events. Refer to Triggers to learn more about this input field.
Limit Enter the maximum number of entries you plan to retrieve each trigger event. The maximum is 1,000 entries.
Entry search filter Enter LDAP filters (opens new window) to add conditions that newly created or updated entries must meet to trigger a job. For example, enter (ou=Dev)(objectClass=Person) to retrieve only Person entries from the Dev organization unit.
The New/updated entry trigger's output includes values from the new or updated entry for each attribute defined by the reference entry.
Last updated: 1/19/2026, 4:31:14 PM
On this page
