# Azure Monitor - Send custom log action
The Send custom log action allows you to send custom logs to Azure Monitor.
Input field Description
Log type Enter the record type of the submitted data. The log type can only contain letters, numbers, and underscores _, and must be 100 characters or less. For example, AzureMonitorTest.
Events Enter the log event you plan to send to Azure Monitor. Select any GUID record types as strings. You can use JSON or add fields manually.
Azure resource ID Enter the resource ID of the Azure resource associated with the data. This populates the _ResourceId property and allows the data to be included in resource-context queries. If this field isn't specified, the data is not included in resource-context queries.
Output field Description
Status Indicates if the custom log was sent successfully.
Last updated: 7/25/2025, 5:11:08 PM
On this page
