# BambooHR – Create table record of employee action
The Create table record of employee action adds a new row to an employee's table in BambooHR. You must specify the employee's internal ID and select the target table. This action supports standard and custom tables.
You can use the Get table records of employee action to retrieve available row IDs from a specific table.
Input field Description
Employee ID Enter the internal BambooHR ID of the employee.
Table Choose the target table where you plan to create the record. For example, select commission to insert a commission record.
Additional input fields may appear based on the selected Table.
Output field Description
Success Indicates the result of the table record creation.
Last updated: 1/12/2026, 10:23:47 PM
On this page
