# Files.com - Create record action
The Create record action creates a new record, including files and folders, in Files.com.
Input field Description
Object Select the Files.com object you plan to create a new record of.
Path Enter the path where you plan to create a record. For example: folder/file.txt.
Create parent directories Select Yes or No to indicate if you plan to create parent directories if they do not exist.
Provided modified time Enter a custom creation timestamp for the record.
The following are the most common output fields. Refer to the Files.com (opens new window) documentation for a complete list of output fields.
Output field Description
Path The path where the newly created record is located.
Created by ID The ID of the user that created the new record.
Display name The name of the new record that is displayed.
Type The type of new record.
Size The size of the new record.
Created at The time that the new record was created.
Last updated: 2/24/2026, 6:47:33 PM
On this page
