# Files.com - Execute operation action
The Execute operation action executes file operations in Files.com.
| Operation | Select the file operation to execute. Available operations include Copy file/folder, Move file/folder, Extract ZIP file, and Create ZIP file. |
| Path | Enter the current path to the file or folder. For example: folder/file.txt |
| Destination | Enter the destination path for the file or folder. For example: folder/file.txt |
| Overwrite | Select whether to overwrite existing file(s) in the destination file or folder. |
| Structure | Select Yes to copy the structure only, without file contents. Select No to copy both the structure and file contents. |
| Status | A message indicating the status of the operation, such as pending. |
| File migration ID | A unique ID assigned to the file on which the operation was performed. |
Last updated: 2/24/2026, 6:47:33 PM
