# Google Calendar - Delete event action
The Delete event action removes an existing event from a calendar you specify.
ENSURE CALENDAR ACCESS
Ensure the calendar you plan to modify is accessible from your connected account that you have the necessary permissions to delete events.
| Calendar | Select the calendar from which you plan to delete an event. |
| Event ID | Enter the Google Calendar ID of the event you plan to delete. Alternatively, you can switch this field to Enter event name enter the name of the event you plan to delete. |
| Send notification? | Select whether to send notifications about the deletion of the event. This field may be deprecated based on the specific implementation in your system. |
This action does not have any output fields.
