# Google Gemini - Generate text embedding action
The Generate text embedding action generates an embedding from the provided text. Text embedding is a technique for representing text as numerical vectors. It uses deep neural networks trained on large text sets to generate vector representations that capture the meaning and context of a text.
| Model | Select the Gemini model to use. |
| Text for embedding generation | Provide the text to convert into an embedding. Input text must not exceed 8192 tokens (approximately 6000 words). |
| Value | The vector (embedding) returned by Gemini. |
| Sexually explicit | The likelihood that the text contains sexually explicit content. NEGLIGIBLE indicates there is little to no risk of such content being present. |
| Hate speech | The likelihood that the text contains or promotes hate speech, such as discriminatory symbols or context targeting protected groups. NEGLIGIBLE indicates there is little to no risk of such content being present. |
| Harassment | The likelihood that the text contains harassing behavior, threats, or abuse toward individuals or groups. NEGLIGIBLE indicates there is little to no risk of such content being present. |
| Dangerous content | The likelihood that the text contains dangerous or harmful content such as violence, self-harm, or instructions for unsafe behavior. NEGLIGIBLE indicates there is little to no risk of such content being present. |
Last updated: 7/14/2025, 6:17:38 PM
