# Google Gemini - Parse text action
The Parse text action extracts data you specify from a provided text.
| Model | Select the Gemini model to use. |
| Source text | Provide the text to parse. |
| Fields to identify | Enter the fields that you want to identify from the text. |
This action returns the fields defined in the Fields to identify section, along with the following fields:
| Sexually explicit | The likelihood that the text contains sexually explicit content. NEGLIGIBLE indicates there is little to no risk of such content being present. |
| Hate speech | The likelihood that the text contains or promotes hate speech, such as discriminatory symbols or context targeting protected groups. NEGLIGIBLE indicates there is little to no risk of such content being present. |
| Harassment | The likelihood that the text contains harassing behavior, threats, or abuse toward individuals or groups. NEGLIGIBLE indicates there is little to no risk of such content being present. |
| Dangerous content | The likelihood that the text contains dangerous or harmful content such as violence, self-harm, or instructions for unsafe behavior. NEGLIGIBLE indicates there is little to no risk of such content being present. |
Last updated: 7/14/2025, 6:17:38 PM
