# Google vault - Add accounts to hold
The Add accounts to hold action enables you to add accounts to an account-based hold in Google Vault.
Google Vault Add accounts to hold action
Input Field | Description |
Hold ID | Use the Hold ID drop-down menu to select a hold from Google Vault, or enter the ID manually |
Matter ID | Use the Matter ID drop-down menu to select a hold from Google Vault, or enter the ID manually |
Account emails | Enter a comma-separated list of email addresses for the accounts to add to the hold. |
Account IDs | Enter a comma-separated list of account IDs to add to the hold. Specify either emails or account IDs, not both. |
Details output field | Describe custom output fields present in the details of the output schema. |
Output Field | Description |
Account ID | ID of the account added to the hold. |
Hold time | Timestamp of when the account was put on hold. |
The primary email address of the account. | |
First name | The first name of the account holder. |
Last name | The last name of the account holder. |
Code | The HTTP response status code. |
Message | A developer-facing error message, if any. |
Details | A list of messages that contains additional error details, if any. |
